plt3DILegend GetMax
Gets the maximum result value.
plt3DILegend_handle GetMax
HyperWorks Tcl Query
Returns the maximum value.
None.
View new features for HyperWorks Desktop 2021.1.
Gets a handle to a cloned copy of this legend.
Returns the color at the given level index.
Gets the default script file path.
Gets the default legend state.
Finds the legend style.
Gets the text attribute handle for the footer text.
Gets the header text.
Gets a font handle for the header font.
Gets whether the legend is highlighted.
Gets a named meta-data value previously associated with the legend.
Gets the minimum result value.
Gets the maximum and minimum legend visibility state.
Gets the text attribute handle for the legend numbers.
Gets the number of color levels.
Gets the precision used by the legend.
Gets the position of the legend.
Enables/disables the reverse state of the legend.
Gets the legend title.
Gets the text attribute handle for the legend title.
Gets the legend type.
Gets the value at the given level index.
Gets the legend visibility.
Interpolates the legend colors.
Gets the override state of the given color level.
Sets a user-defined value for the given color level.
Recalculates the legend min and max from plot data.
Releases the handle to all clones copies of the legend.
Resets the colors and number format to the default values.
Sets the color of the level.
Sets the default state of the legend.
Sets the legend style.
Sets the legend footer text.
Sets the legend header text.
Sets whether the legend is highlighted.
Sets the maximum value.
Associates a named meta-data value with the legend.
Sets the minimum value.
Enables/disables the display of the max and min values with the legend.
Sets the number of legend color levels.
Sets the format for numbers.
Sets the precision for numbers.
Sets the location of the legend.
Sets the legend title.
Sets the legend type.
Sets the legend visibility.
Applies the settings for the cloned legend to the original legend.
Removes the override value for the given color level.
ON THIS PAGE
None.
ON THIS PAGE
