plt3DICurve GetLineThickness
Gets the line thickness of the curve.
plt3DICurve_handle GetLineThickness
HyperWorks Tcl Query
None.
View new features for HyperWorks Desktop 2021.1.
Creates a new cursor in HyperGraph 3D.
Gets a handle to a plt3DIIterator interface for Curve.
Adds a point to a 3D curve and optionally sorts the points.
Gets a pointer to an hwICursor.
Gets the handle of the curves’ owner (a curve group).
Gets a handle to a pulIDataSource for the specified curve.
Gets whether or not the curve is displayed in the legend.
Gets the highlight state of the curve.
Gets the line color of the curve.
Gets the line style of the curve.
Gets a named meta-data value previously associated with the curve.
Gets the number of cursors on the curve.
Gets the number of points on the curve.
Gets whether a curves X, Y, and Z vectors are parameterized by a U vector.
Returns the curve’s shadow color index.
Returns the shadow’s filled state.
Gets opacity of the shadow under the curve.
Gets the shadow plane of the curve.
Gets whether the shadow under the curve is transparent.
Returns the shadow visibility state.
Gets the symbol color of the curve.
Gets the symbol frequency of the curve.
Gets the size of symbols along the curve.
Gets the symbol style of the curve.
Returns the curve’s visibility state.
Removes a cursor from HyperGraph 3D.
Sets whether or not the curve is displayed in the legend.
Sets the curve’s highlight state.
None.
