HWCFD-T: 1020 Wrapping Using the Template Manager
Before you begin, click here to download the tutorial models. Extract Wrapping_Example_Engine.hm from the zip file.
If you have local help installed, you can access the model files in <Altair Installation>\tutorials\hwdesktop\hwcfd.
Create Groups
- Open the Wrapping_Example_Engine.hm file.
- Make sure the entity selector in the modeling window is set to Parts.
Select the three bolts parts highlighted in the figure below.
Figure 1. -
Right-click and select Find and Isolate > Matching Parts.
The tool searches for all bolts matching the features of the highlighted parts and isolates them on the screen.
Figure 2. - Left-click and drag to select all the bolts on the screen then right-click and select Create Group.
- Label the group Misc then click Create.
Right-click and select Reverse (R) to display all the
parts besides the bolts.
Figure 3. - Left-click and drag to select all the parts on the screen then right-click and select Create Group.
- Label the group ToWrap then click Create.
Create the Template
Click the arrow next to the Home tool set, then
select Template Manager.
Figure 4. - Select Operation from the list of categories in the Template Manager dialog.
Click
to add an operation.
Figure 5. -
Double-click in the Operation column and select
Tessellation.
Figure 6. -
Click
in the Definition column. Ensure that the Unmeshed
surface meshing method is set to Faceting with a size
definition set to Normal.
Click
to add another operation.
- Double-click in the Operation column and select Cap.
- Under the Selection Mode column, select By user groups.
Under the User Group Selection column, select
ToWrap.
Figure 7. -
Click
and enter a maximum width of
100.
Figure 8. -
Click
- Double-click in the Operation column and select Wrap.
ToWrap.
Figure 9. -
Click
and enter a value of 20 for
the Average element size.
Figure 10. -
Click
- Double-click in the Operation column and select Re-mesh.
ToWrap.
Figure 11. -
Click
the Average size.
Figure 12. -
Click
- Double-click in the Operation column and select Fix Surface Mesh Quality.
ToWrap.
Figure 13. -
Click
and enable Degenerated element
cleanup, Duplicate element cleanup,
Aspect ratio cleanup, and Intersection
cleanup.
Figure 14. -
Click
- Double-click in the Operation column and select Delete.
Misc.
Figure 15. - At the bottom of the dialog, enable Run operations and Validation.
Click
next to Validation and set the Sliver Surface Threshold to
0.0001.
Figure 16. - Click Run to execute the template.
Save the Template
Click
- Enter a name for the file.
- Click Save.
- Close the Template Manager.
Observe that the Validate tool on the Geometry ribbon has a blue check mark,
which indicates that the validation was successful.
Figure 17.
