HWCFD-T: 1000 Basic Geometry Editing
Before you begin, click here to download the tutorial models. Extract Manifold_Model.hm from the zip file.
If you have local help installed, you can access the model files in <Altair Installation>\tutorials\hwdesktop\hwcfd.
Validate the Geometry
Fix Surfaces
Extract the Fluid Domain
In this step, you will use the solid geometry to extract the internal fluid as a part, which you will then use for the simulation.
