HWCFD-T: 1010 Wrapping Workflow
Before you begin, click here to download the tutorial models. Extract PowerTrain_Model_Defeaturing.hm from the zip file.
If you have local help installed, you can access the model files in <Altair Installation>\tutorials\hwdesktop\hwcfd.
Group the Solids to be Wrapped
- Open the PowerTrain_Model_Defeaturing.hm file.
- Make sure the entity selector in the modeling window is set to Parts.
While holding the Ctrl key,
select the solids depicted in the figure below.
Figure 1. -
From the Home tools, click the Group tool.
Figure 2. -
Make sure that you have 7 parts selected by observing the number in parentheses
on the guide bar selector.
Figure 3. -
On the guide bar, click
to execute the command and remain in the
tool.
Figure 4. - In the Groups legend, rename the Parts Group to For_Wrapping.
Right-click For_Wrapping and select
Isolate.
This displays only the parts that will be wrapped.
to exit
the tool.
- Save the model.
Convert CAD Geometry to an FE (Tessellated) Model
From the Geometry ribbon, click the Convert tool.
Figure 5.The Convert CAD to FE dialog opens. -
Ensure that Faceting is selected for the Unmeshed
surface meshing method and that the faceting size definition is set to
Normal.
Figure 6. - Click Convert.
- Press Esc to exit the tool.
- Save the model.
Cap Holes and Other Openings
Small holes and other openings which only increase the mesh count and do not contribute to the simulation are capped/closed off before the wrapping of the geometry is done.
- Ensure that you have only the parts belonging to the "For_Wrapping" group displayed on the screen. If not, click the Group tool, right-click on For_Wrapping in the legend, and select Isolate.
Click the Wrap tool.
Figure 7. -
From the secondary ribbon, click the Cap tool.
Figure 8. - Enter a value of 40 for the Maximum Width.
Select all surfaces on the screen using one of the following methods:
- Left-click and drag over the entire model.
- Press Ctrl + A.
Ensure that you have 2925 surfaces displayed on the guide bar's surface selector.
Figure 9. - Click Cap to begin the capping process.
- Change the guide bar selector from Surfaces to Nodes.
Select the four nodes shown in Figure 10.
Figure 10. - Click Cap to begin the capping process.
Click the Run tool on the Wrap secondary ribbon.
Figure 11. -
In the dialog, enter the value of 20 for the Average
element size and leave all other options as their default values.
Figure 12. - Select all surfaces on the screen.
- Click Wrap to execute the wrapping operation.
- Save the model.
Re-mesh Wrapped Results
Click the Mesh tool.
Figure 13. - Select all surfaces on the screen.
In the dialog, set the Average size to 20 and leave all
Figure 14. - Click Mesh on the guide bar to execute the re-mesh operation.
- Save the model.
Fix Wrapped Geometry
Click the Fix tool.
Figure 15. - Select all surfaces on the screen.
Click
on the guide bar. Ensure
that Degenerated element cleanup, Duplicate
element cleanup, Aspect ratio cleanup,
and Intersection cleanup are checked.
Figure 16. - Click Fix to initiate the repair of the wrapped surface model.
Save the model.
Figure 17.
