Define Surface Mesh Size
Use the Surface tool to define local mesh settings on selected surfaces.
  1. Select the surfaces on which to apply the mesh control in the following ways:
    • While in the Mesh ribbon, select surfaces, then right-click and select Assign Mesh Controls > Surface Mesh from the context menu.
    • From the Mesh ribbon, click the Surface tool.
      Select surfaces.
  2. In the dialog, define surface mesh options.
  3. From the guide bar, execute the command in the following ways:
    • Click to confirm your selection and remain in the tool.
      This allows you to continue creating instances and helps you visualize and edit instances with the legend.
    • Click to confirm your selection and exit the tool.
