Deactivate Mesh Controls
Use the right-click context menu on the legend to deactivate mesh controls. This excludes them from consideration when processing the solution.
  1. Activate any of the tools in the Mesh Controls tool set.
    The corresponding legend displays in the top-left of the modeling window.
  2. Right-click on an instance in the legend and select Deactivate from the context menu.
    The instance is greyed out, indicating that it is deactivated.
Tip: To make a mesh control active again, right-click on a deactivated instance in the legend and select Activate from the context menu.
