Radioss Interface 2021 Release Notes
Radioss Interface
New Features
- Support of Radioss solver version 2021
- The new Radioss solver version 2021 is supported along with major keywords updates.
- Elemental time step quality criteria
- The shell elemental time step is now available as meshing quality
criteria, which adapts the quality of the mesh with respect to the
solver elemental time step value.
Figure 1. - New encryption
- The new encryption using the keyword /ENCRYPT is now fully supported and
encrypts Materials, Properties, Curves, and Failure keywords. The
encryption process can now be started from the contact menu of the
entities in their dedicated browser views. An additional column is added
to inform you about the keywords that are encrypted.
Resolved Issues
- Issue 1: /BEGIN card is now editable in the Model Browser.
- Issue 2: Some keywords were incorrectly grouped as “ungrouped” into the Model Browser.
Altair HyperCrash
New Features
- New Radioss 2021 Solver Interface
- The new Radioss solver version 2021 is supported.
- New Keywords
- The following Radioss keywords have been
added:
- /MONVOL/FVMBAG2
- /MERGE/RBODY
- /FUNCT_SMOOTH
- /MAT/LAW108
- /MAT/LAW101
- /FRIC_ORIENT
Enhancements
- Updated Keywords
- The following keywords have been updated to in Radioss solver versions
2020 and 2020.1:
- /FAIL/ENERGY
- /FAIL/HASHIN
- /FAIL/VISUAL
- /INTER/TYPE19
- /MAT/LAW51
- /MAT/LAW63
- /MAT/LAW81
- /MAT/LAW92
- /MAT/LAW94
- /MAT/LAW95
- /MAT/LAW100
- /PROP/TYPE6
- Connections
- Enhancements were made to the import/export csv file with connected part IDs instead of property IDs.
- Solver Conversion
- The following LS-Dyna keywords are now fully supported in the conversion
to the Radioss solver:
- *DEFINE_FRICTION
- *MAT_ADD_EROSION
- *MAT_119
- *MAT_083
Resolved Issues
- Issue in position calculation for LS-DYNA *DEFINE_TRANFORMATION using POINT and ROTATE ins sequence
- Issue in Radioss result initializer process when 0 integration is defined in the shell property card
- Issue in model checker when checking if any material stress-strain curves are crossing each other. The check is now enhanced to report all valid errors of material curves definitions.
Announcements
- Due to the removal of HyperMesh standalone, all the links to start HyperMesh from HyperCrash have become obsolete and have been removed.
