Optimisation Output
Information on the optimisation process is stored in a .log file.
The optimisation process may be interrupted at any time by clicking the Stop in the GUI process information window, or Ctrl+C in a command line. If an optimisation is interrupted, all of the interim files created during the optimisation will be kept, except if the Delete all files option was selected when running from the GUI, or if the -r option was added when running from a command line. If the files were kept, the optimisation can be restarted at a later stage using the –restart x option.
