Submitting Jobs to the Cluster
Execute the Farm RCS sweep to a PBS cluster application macro in CADFEKO to split a model into smaller runs with one frequency and angle of incidence (phi and theta) to a cluster.
An application macro is a reference to an automation script, an icon file and associated metadata.
The application macro library allows commonly used application macros to be stored in a repository.
A collection of Lua application macros are available to automate repetitive tasks in CADFEKO.
A collection of Lua application macros are available to automate repetitive tasks in POSTFEKO.
A collection of Lua macros are available to automate repetitive tasks where the workflow span both CADFEKO and POSTFEKO.
It is possible to convert between the loss tangent and conductivity description of the material losses at a single frequency. This application macro performs the calculation and can be used in CADFEKO and POSTFEKO.
This application macro is used to divide a larger model with many frequency points, and plane wave sources requested in multiple directions into sub-problems with a single frequency point and plane wave. The sub-problems are executed concurrently on a cluster reducing the run time to solve the larger problem.
The application macro is divided into two parts. The first part in CADFEKO creates and submits the models to a cluster. The second part in POSTFEKO merges the results.
Set up an RCS sweep configuration. The farm_rcs_to_cluster.lua uses the frequency and incident angle information from plane wave sources in the model to create the sweep.
The job template file contains a set of instructions for the PBS cluster. This list of commands is used for each sweep configuration when submitting the runs to the cluster.
Execute the combine_rcs_sweep_results.lua in POSTFEKO to merge the results completed from the cluster run.
The farming application macro has limitations on sweep combinations that can be requested for frequency and angle sweeps.
A collection of smaller shared application macros are available, but these macros do not include step-by-step instructions.
Once the models are submitted to the cluster, the following dialog is shown.
