Overview
The application macro is divided into two parts. The first part in CADFEKO creates and submits the models to a cluster. The second part in POSTFEKO merges the results.
- Farm RCS sweep to a PBS cluster: The application macro splits the original CADFEKO model into individual models using the frequency and plane wave source setup per configuration and submits the models to a PBS cluster. Each model is simulated with one frequency and a single incident wave (theta, phi).
- Combine RCS sweep results from cluster: The application macro uses a .xml summary file as input to merge the individual runs from the cluster and store the data in POSTFEKO.
