Defining Calculation Requests
Define the calculation requests in CADFEKO.
Create a full 3D far field request (-180°θ≤180° and 0°ϕ≤180°). Sample the far field at θ=5° and ϕ=5° steps.
  1. Enable the option, Calculate continuous far field data.
    Tip: Open the Request/Modify far fields dialog, click the Advanced tab and then select the Calculate continuous far field data check box.
    Tip: Spatially continuous far fields allow the far field to be re-sampled to any resolution in POSTFEKO.
