Rotate
This option is used to rotate the selected objects. The user will select the objects and enter the coordinates of the points that form the rotation axis and the angle of rotation and press enter, as shown in the following figure.
![](../../../../../images/newfasant/gui/edit_menu/geometric_operations/14.png)
Figure 1. Selecting the surface to rotate
After selecting the surface and having selected the option to rotate, introduce the desired points. The result appears in the next Figure.
![](../../../../../images/newfasant/gui/edit_menu/geometric_operations/15.png)
Figure 2. Rotate
