Optimisation
Optimisation data such as optimised parameters, goals, global goals and masks can be viewed on a Cartesian graph after OPTFEKO was used to calculate the results.
On the Home tab, in the
Add results group, click the Optimisation icon.
![](../../../../images/feko/user_guide/postfeko/optimisation_result_palette.png)
Figure 1. Example of the result palette for optimisation. The Independent axis (Horizontal) is set as the Optimisation run number.
