Creating a Smith Chart
A Smith chart allows you to view complex impedance, admittance, reflection coefficient and S-parameters.
![](../../bank/ribbon/../../../../images/feko/icons/button_smith_chart.png)
![](../../../../images/feko/user_guide/postfeko/dialog_smith_chart.png)
Figure 1. Examples of a Smith chart (impedance and admittance).
Use POSTFEKO to validate meshed geometry and analyse and post-process results.
View the main elements and terminology in the POSTFEKO graphical user interface (GUI).
POSTFEKO has various default settings that you can configure to customise it to your preference.
A number of rendering options are available to ensure that 3D models and graphs (containing a large number of sample points) are rendered efficiently.
You can add a model, open an existing project and save the project.
Import text files, native data files and Touchstone format files.
POSTFEKO supports the export of native file formats. These files can be exported to use in other sessions or when further post-processing is required.
The terms, dataset, slice, trace and 3D result, are used extensively in the documentation. Review the definitions to get a better concept of these definitions.
Display result data on a graph to allow visual interpretation of the data in a human-readable format, as well as to communicate the results in reports and presentations.
POSTFEKO supports three types of graphs, namely Cartesian graph, polar graph and Smith chart. Each graph type represents data in a different way to make it easier to interpret for a given application.
A Cartesian graph is the classical line graph and most simple graph type. This graph type is used when you want to view closely related series of data. Any data can be viewed on a Cartesian graph.
A polar graph allows you to plot data that has at least one angular axis. You can either plot a full polar graph or only display a sector of the polar graph.
Modify the default grid type from impedance to admittance.
For the first five times that POSTFEKO is started after installation, an overlay image is displayed to guide you on how to add data. The overlay image is removed once data is added to the graph.
A number of settings are available to customise a graph. From changing the font, font size, adding fill, changing the marker styling, adding shapes and text boxes, editing the graph title, footer and many more settings to obtain graphs that suits your styling.
A graph legend is a summary of the trace or traces displayed on the graph. The legend also indicates which colour represents each trace on the legend
Use annotations and cursors to read and interpret plotted results.
Add an image to a Cartesian graph, polar graph or Smith chart to better interpret and understand the results.
Create a duplicate view of a graph, complete with all settings.
Create a copy of the graph and change the graph type (if the data is compatible with both). For example, create a polar graph copy from a Cartesian graph.
A trace is a line plotted on a graph that represents a quantity relative to an independent axis. The styling of the trace as well as the representation of the data can be manipulated.
A Cartesian surface graph is a flat colour plot with results plotted against two independent axes.
View the simulation data in a 3D view to allow visual interpretation of the data in a human-readable format, as well as to communicate the results in reports and presentations. The 3D view can also be used to verify that the CADFEKO or EDITFEKO model is correct.
The Solver contains a number of frequency domain solution methods, as well as a time domain solution method. By default, all simulation results are obtained in the frequency domain, unless explicitly using the time analysis tool in POSTFEKO to convert the results to the time domain.
With the time analysis tool in POSTFEKO, electromagnetic scattering problems can be analysed in the time domain. The time domain results are obtained by applying an inverse fast Fourier transformation (IFFT) on the frequency domain simulation results.
Use animation to obtain a better understanding of results or export the animation to use in a presentation or report.
POSTFEKO is a useful tool to help analyse and present data in a useful format. It is often required to use the processed results in a report or presentation. To help make it easier to generate these reports, several tools are available in POSTFEKO.
Feko provides a powerful scripting language that allows you to create scripts that control CADFEKO and POSTFEKO.
POSTFEKO has a collection of tools that allow you to quickly validate the model, for example, measure distances, measure angles and finding specific mesh elements.
View the files associated and generated by POSTFEKO.
