Units
When working with a CADFEKO model in EDITFEKO, the units are considered to be in metres (if the solution configuration is disabled in CADFEKO).
Use an SF card in the geometry section of the .pre file to specify the units. For example, if the model was constructed in millimetres, an SF card with a 0.001 scale factor should be added to the .pre file.
