Multiple Configurations
Obtain multiple solutions for a single model using multiple configurations. Multiple configurations remove the requirement to create multiple models with different solution requests.
- Calculate the input impedance of a patch antenna over a frequency range (Configuration 1) and the radiated far field at the centre frequency (Configuration 2).
- Calculate the antenna parameters of a dual-band antenna over two frequency bands (Configuration 1 and Configuration 2).
- Calculate the current on a wire above ground in three configurations:
- Terminated in an open circuit (Configuration 1).
- Terminated in short circuit (Configuration 2).
- Terminated with a matched load or system impedance (Configuration 3).
- Calculate the two-port S-parameters of a system (Configuration 1) and the radiated currents when both ports are active at the same time (Configuration 2).
