Defining an Infinite Planar Multilayer Substrate
Define an infinite planar multilayer substrate.
Some applications for infinite planar multilayer substrates are as follows:
  • Add a PEC ground plane at the top and bottom layers to model a stripline.
  • Add a PEC ground plane at the bottom layer to model a microstrip.
  • Use the substrate (without a PEC ground plane) to model real earth.
  • Use a finite thickness substrate without any ground plane to model a printed antenna (for example, a log-periodic antenna).
  1. On the Construct tab, in the Structures group, click the  Planes/arrays icon. From the drop-down list, select  Plane / ground.
    Figure 1. The Plane / ground dialog.
  2. Under Ground medium, click Planar multilayer substrate.
  3. Click Add to add an additional layer. Click Remove to remove the selected layer from the substrate.
  4. For each layer:
    1. From the Ground plane drop-down list, select one of the following:
      • To remove the PEC ground plane located below the current layer, click None.
      • To add a PEC ground plane located below the current layer, click PEC.
    2. Specify the layer thickness.
    3. Specify the medium.
    Note:
    • The top layer and bottom layer consist of free space and extends into infinity.
    • In the CADFEKO GUI, the first layer is indexed as 0.
    • In the CADFEKO API, the first layer is indexed as 1.
  5. Click OK to define the infinite planar multilayer substrate and close the dialog.
