Farm RCS Sweep to a Cluster Macro
This application macro is used to divide a larger model with many frequency points, and plane wave sources requested in multiple directions into sub-problems with a single frequency point and plane wave. The sub-problems are executed concurrently on a cluster reducing the run time to solve the larger problem.
