Creating the Port
Define a wire port on the feed pin. A voltage source will be added to this port.
Select Union1.
- In the model tree, select Union1.
- In the details tree, select the wire of Union1.
Define a wire port using one of the following workflows:
- On the Source/Load tab, in the
Ports group, click the
Wire port icon.
- In the details tree, a right-click context menu is available on the wire. From the drop-down list, select Create port > Wire port.
Under Location on wire, select
Middle.
- Click Create to create the port and to close the dialog.
