Topics Discussed in Example
Before starting this example, check if the topics discussed in this example are relevant to the intended application and experience level.
- CADFEKO
- Create a planar multilayer dielectric substrate.
- Create a finite sized dielectric substrate.
- Compare the computational resource requirements using different modelling techniques.
- Specify symmetry to save computational resources.
- Add a voltage source to a wire segment.
- Mesh the model.
- Run CEM validate to ensure the model is electromagnetically validated.
- Run the Solver
- POSTFEKO
- View the simulated input reflection coefficient on a Cartesian graph.
- View the simulated real and imaginary parts of the input impedance on a Cartesian graph.
- Altair/2021/help/feko/examples/GetStarted_models/Project3-Patch_Antennas/Patch1_Greens_function/Patch_Infinite.cfx
- Altair/2021/help/feko/examples/GetStarted_models/Project3-Patch_Antennas/Patch2_Finite_substrate/Patch_Finite.cfx
