Combine
Combine two or more surface objects, that share at least one coincident edge, into a single surface object.
This tool outputs a single Combine object.
Combine has three distinct use cases:
- Combine two or more different objects such as a curve and a surface into a single object. This case is purely for the convenience of grouping objects. However, this differs from the traditional operation of creating a group (ALT+G) in that, the combine object is a single entity, not a folder containing objects.
- Combine two or more similar objects such two curves or two surfaces into a single object. This case is useful when you want to perform a single operation on a set of curves or surfaces.
- Combine surfaces that share coincident edges, thereby effectively
stitching them into a solid.Note: This is a rare case where the input surfaces must be at least position continuous forming a closed geometry. To verify if combine created a solid, use the Tolerance checktool under Analysis.
- On the ribbon, click the Modify tab.
Click the Combine icon.
- Combine two or more different objects such as a curve and a surface into a single object. This case is purely for the convenience of grouping objects. However, this differs from the traditional operation of creating a group (ALT + G) in that, the combine object is a single entity, not a folder containing objects.
Combine surfaces that share coincident edges, thereby effectively stitching
them into a solid.
Note: This is a rare case where the input surfaces must be at least position continues forming a closed geometry. To verify if combine created a solid, use the Tolerance check tool under Analysis.
- Select the objects. Right-click to confirm.
