Basic Elements: Planar Walls with Polygonal Shape
Indoor vector databases allow the description of each arbitrary object. To limit the complexity of the file and data format, WinProp supports only planar objects. In the indoor database, they are called walls – but such planar elements are obviously not limited to walls.
Figure 1. Approximation of round objects with planar objects.
