Untrim
Remove selected edges and extend remaining edges to close the surface.
On the ribbon, click the Direct tab.
Note: Untrim only works on objects without construction history. To collapse the construction history of a selected object, press Alt+C.
Click the Untrim icon.
- Select the object.
To change the selection method, in the guide bar, select one of the following
options:
- Standard Selection
- Chain Selection: If you click an edge, all connected edges are selected automatically.
- Single Selection: You can only select one edge at a time.
- Select the edges to remove. Right-click to confirm.
