Loft
Create one or more surfaces that extend from the part to the binder, to aid in stretching and forming.
Rib Options
Microdialog Options
Option | Description | Note |
Rib plane orientation | Enter an angle to define the orientation of the rib plane.
Alternatively, drag the yellow arrow that appears when you hover over the rib. |
Align to XY draw plane | Rotate the selected rib so that it’s parallel to the XY draw plane. | |
Addendum configuration | Select one of the following options:
This option is not available when the rib is coincident with the plane. |
Angle | Enter a value to change the angle of the selected rib. | |
Length | Enter a value to change the length of the selected rib. | |
Tangency (G1) to the part | Create ribs with tangent (G1) continuity to the part at the start of the rib. | This option is not available when the rib is coincident with the plane. |
Radius | The radius of the selected fillet. |
Control Panel Options
Edge discontinuity tolerance | To achieve tangency discontinuity, define the minimum value
of the common angle between the tangent edges along the addendum
start edge. On the part edge, when tangency discontinuity is greater than the specified Edge discontinuity tolerance, a discontinuity vertex results (indicated by a red dot), and a rib is created. The default value is 3 degrees. Enter a value between 0 and 3 degrees. |
Min. edge discontinuity for corner | To be considered a corner, define the minimum value of the
common angle between the tangent edges along the addendum start
edge. On the part edge, when tangency continuity is greater than the specified Min. edge discontinuity for corner, a corner results (indicated by a red dot), and two or more ribs are created here. The default value is 45 degrees. Enter a value between 30 and 90 degrees. |
Auto create rib locations | Select where you want to automatically create ribs:
Continuity at part edge | Define the continuity of the addendum surface with the part
edge by selecting one of the following options:
Auto create rail | Select this option to automatically create additional rail curves at the start of addendum wall. These rail curves are used to create the addendum surface. |
Draft analysis | Select this option to display severe negative drafts in red
and marginal negative drafts in yellow. Note: To return to
modifying the addendum, deselect Draft
analysis.
Smoothing distance | Adjust the smoothness level of the area where the addendum intersects the binder. |
