New to Inspire PolyFoam? Learn the basics here.
Learn the basics of the Inspire user interface.
Learn how to import geometry and export results.
Discover new features and enhancements.
Inspire PolyFoam is an essential toolset to simulate and validate the part design and physical processes that are required to create a polyurethane foam part.
Five basic steps are required to define and run a foaming analysis.
The Inspire PolyFoam workspace includes the ribbon, modeling window, legend, model browser, property editor, and status bar.
Create, open, save, or revert a model using standard keyboard shortcuts, the Files icon, or the File menu.
Import and merge a saved model with the current model.
Export geometry and simulation results for use in another application.
View a list of supported file formats for import and export.
Review techniques for selecting and editing objects.
Change the view in the modeling window using the mouse or view controls.
Translate, rotate, and align parts and other objects using the Move tool and snaps.
Record a video or take a snapshot of the screen.
Change the default unit system, create custom units, and measure geometry features.
Browse and organize all of the entities in your model.
Learn about the forms of help and user assistance available from the product.
Modify the workspace display, default keyboard shortcuts, and other settings.
A list of supported operating systems and minimum requirements for hardware and memory.
Learn keyboard shortcuts and mouse controls for common operations.
View a list of glossary terms and definitions.
Start using Inspire PolyFoam with our interactive tutorials.
Create and modify sketch curves, surfaces, and solids.
Set up your model parts, materials, nozzle paths, tooling and process parameters prior to analysis.
Run an analysis to minimize defects and prevent manufacturing problems for a foam part design.
