Runtime Parameters Dialog
This dialog allows you to enter required values for parameters defined for the model.
Note that these runtime parameters are most likely tied to filters or computations, and the values you enter will affect the records displayed in Table View or Summary View.
Enter a value into the Value edit box.
The value must match the data type required.
If more than one parameter has been define you must enter a value for all parameters.
Select OK.
Notes:
