Altair® Monarch®
Running Exports
You can easily run exports from within Export View.
Running exports
  1. Go to Export View.
  2. Double-click on exports on the selector. This places the export on the Export Job List panel. If you want to run all exports select Select All Exports on the Export View ribbon.
  3. Select Run Exports on the Export View ribbon. The status of the export run is displayed on the Export Results panel:
    If the export is successful, a hyperlink to the export output is made available. To view the exported file, select the hyperlink to copy the path indicated to your clipboard. You can then paste the link to your file manager to open the resulting file.
Removing exports from the Export Job list
  1. Click on an export on the Export Job List panel. To select more than one export, press CTRL then click on another export.
  2. Select Clear Selected Jobs on the Export View ribbon. The status of the export run is displayed on the Export Results panel.
