The File Open Dialog
A standard File Open dialog allows you to select a source file on your hard drive or network.
Find the file or folder that you want to open.
Double-click the file or folder to open it, or select the file and click Open.
Depending on the data source you select, one of the following happen:
You are brought to the Preview window, where you can view, select and/or load tables to use.
You are brought to the Report Design window, where you can define the fields to use from PDF and report files.
You are brought to the Worksheet Design window, where you can define the fields to use from non-tabular Excel worksheets.
Note
You can bypass the File Open dialog and open a data source immediately by dragging the file from Windows Explorer to the Start or Preview window.
Note that the delimited text importer has been updated in Monarch Complete version 2020.1. Thus, workspaces containing this new importer will be rendered unusable in older versions of the software. A version compatibility warning displays before the workspace is saved to alert you of this potential issue.
