Duplicating a Summary
When creating several similar summaries, you can save time by using the first definition as the starting point for subsequent definitions. Monarch Classic makes this process easy.
Go to Summary Design.
Display the properties of a summary by selecting it on the selector.
Select Duplicate on the Summary Design Ribbon. A copy of the currently selected summary is automatically created.
Rename and edit the duplicate as required.
The duplicate summary's default name is Summary.
