Select a surface, define the thickness and direction, and click Extract to define
where the surface is represented.
Click on the Geometry tab.
Click on the Feasibility
tab.
Select the Midsurface tool.
Select a surface.
A transparent preview of a thin solid part with the surface positioned
at the midsurface is shown.
Type the thickness of the thin solid part in the microdialog and press
Enter.
Click the
icon to preview the thickness direction. Click the
icon again to change the direction.
Click the preview to confirm the thickness direction and extract the desired
face.
Tip:
- To restore the original surface, click the extracted face and select the
surface in the microdialog.
