Coupler Requires Joints to be Rigid and Active
Condition
This error message has two versions:
  • Coupler Requires Joints to be Rigid and Active
  • Coupler Requires Supports to be Rigid
Tip: To avoid this error, click in the guide bar, and then select Force coupled joints to be rigid before creating the coupler.
Cause 1: Coupler Requires Joints to be Rigid and Active
Click Fix to make the coupler's joints active and rigid.
Cause 2: Coupler Requires Supports to be Rigid
Click Fix to make the support behavior rigid for all supports in your model.
