Engine Subroutine SUSERnn for Solid Elements
This subroutine calculates the internal forces and moments.
Arguments
The argument list of RUSERnn is:
C--------------------------------------------------------------------------
SUBROUTINE SUSER29(
     1 NEL    ,NUVAR  ,IOUT   ,IPROP  ,IMAT  ,SOLID_ID,TIME  ,TIMESTEP,
     2 EINT   ,VOL    ,UVAR   ,FR_WAVE,OFF    ,RHO    ,SIG    ,
     3 XX1    ,XX2    ,XX3    ,XX4    ,XX5    ,XX6    ,XX7    ,XX8    ,
     4 YY1    ,YY2    ,YY3    ,YY4    ,YY5    ,YY6    ,YY7    ,YY8    ,
     5 ZZ1    ,ZZ2    ,ZZ3    ,ZZ4    ,ZZ5    ,ZZ6    ,ZZ7    ,ZZ8    ,
     6 UX1    ,UX2    ,UX3    ,UX4    ,UX5    ,UX6    ,UX7    ,UX8    ,
     7 UY1    ,UY2    ,UY3    ,UY4    ,UY5    ,UY6    ,UY7    ,UY8    ,
     8 UZ1    ,UZ2    ,UZ3    ,UZ4    ,UZ5    ,UZ6    ,UZ7    ,UZ8    ,
     9 VX1    ,VX2    ,VX3    ,VX4    ,VX5    ,VX6    ,VX7    ,VX8    ,
     A VY1    ,VY2    ,VY3    ,VY4    ,VY5    ,VY6    ,VY7    ,VY8    ,
     B VZ1    ,VZ2    ,VZ3    ,VZ4    ,VZ5    ,VZ6    ,VZ7    ,VZ8    ,
     C VRX1   ,VRX2   ,VRX3   ,VRX4   ,VRX5   ,VRX6   ,VRX7   ,VRX8   ,
     D VRY1   ,VRY2   ,VRY3   ,VRY4   ,VRY5   ,VRY6   ,VRY7   ,VRY8   ,
     E VRZ1   ,VRZ2   ,VRZ3   ,VRZ4   ,VRZ5   ,VRZ6   ,VRZ7   ,VRZ8   ,
     F FX1    ,FX2    ,FX3    ,FX4    ,FX5    ,FX6    ,FX7    ,FX8    ,
     G FY1    ,FY2    ,FY3    ,FY4    ,FY5    ,FY6    ,FY7    ,FY8    ,
     H FZ1    ,FZ2    ,FZ3    ,FZ4    ,FZ5    ,FZ6    ,FZ7    ,FZ8    ,
     I MX1    ,MX2    ,MX3    ,MX4    ,MX5    ,MX6    ,MX7    ,MX8    ,
     J MY1    ,MY2    ,MY3    ,MY4    ,MY5    ,MY6    ,MY7    ,MY8    ,
     K MZ1    ,MZ2    ,MZ3    ,MZ4    ,MZ5    ,MZ6    ,MZ7    ,MZ8    ,
     L STIFM  ,STIFR  ,VISCM  ,VISCR  )
Argument Format Description
NEL Integer read only scalar Number of elements per group. In Radioss Engine subroutines, the element data are treated by groups for vectorization. This argument is machine-dependent and set by Radioss.
NUVAR Integer scalar Number of extra variables needed for each solid element in SINInn or SUESERnn
IOUT Integer read only scalar Output file unit (L01 file)
IPROP Integer read only scalar Property number.
IMAT Integer read only scalar Material number.
SOLID_ID Integer read only scalar Array of size NEL containing solid element ID.
Time Float read only Current time.
TIMESTEP Float read only Current time step.
EINT Float array read only Array of size NEL containing current total internal energy.
VOL Float array read only Array of size NEL containing initial element volumes. The incoming value is computed with one integration point, which can be recomputed.
UVAR Float array read write Array of size NEL*NUVAR containing user element variables.
OFF Float array read write Array of size NEL containing deleted element flags.
0
If the element is OFF
1
If the element is ON
RHO Float array read write Array of size NEL containing current densities.
SIG Float array read write Array of size 6*NEL containing current stress tensor SX, SY, SZ, SXY, SYZ, and SZX.
XX1 Float array read only Array of size NEL containing X coordinate at node 1 in the global frame at time TIME.
UX1 Float array read only Array of size NEL containing X displacement at node 1 in the global frame at time TIME.
VX1 Float array read only Array of size NEL containing initial X velocity at node 1 in the global frame at time TIME.
VRX1 Float array read only Array of size NEL containing initial X rotational velocity at node 1 in the global frame at time TIME.
FX1 Float array write only Array of size NEL containing X force at node 1 at time TIME.
MX1 Float array write only Array of size NEL containing X moment at node 1 at time TIME.
STIFM Float array write only Array of size NEL containing element translational stiffness in time step computation.
STIFR Float array write only Array of size NEL containing element rotational stiffness in time step computation.
VISCM Float array write only Array of size NEL containing element translational viscosity in time step computation.
VISCR Float array write only Array of size NEL containing element rotational viscosity in time step computation.
  1. STIFM, STIFR, VISCM, and VISCR compute the nodal or element time step. MASS and XINER compute element time step.
  2. RHO and SIG are used for post-processing in time history and animation. The modification of these variables effects only output. RHO and SIG retain initial values, unless they are modified.
