Engine Subroutine FnnLAWC for Shell Elements
This subroutine calculates the criteria of the failure model.
FINTER
(shown below) to get
the value Y of the function for the abscissa
X:Y=FINTER(IFUNC(I),X,NPF,TF,DYDX)
- Variable
- Description
- Y
- Interpolated value
- X
- Abscissa value of the function
- I
- The ith user’s function
- DYDX
- Slope
- NPF, TF
- Private function parameters
Arguments
C----------------------------------------------------------------------------
SUBROUTINE FnnLAWC (
1 NEL ,NUPARAM ,NUVAR ,NFUNC ,IFUNC , NPF ,
2 TF ,TIME ,TIMESTEP ,UPARAM , NGL , IPT
3 NPT0 ,NOT_USE_I1 ,NOT_USE_I2 , NOT_USE_I3 ,
4 SIGNXX ,SIGNYY ,SIGNXY ,SIGNYZ ,SIGNZX ,
5 EPSPXX ,EPSPYY ,EPSPXY ,EPSPYZ ,EPSPZX ,
5 EPSXX ,EPSYY ,EPSXY ,EPSYZ ,EPSZX ,
7 PLA ,DPLA ,EPSP ,UVAR ,UEL ,
8 OFF ,LENGTH, AREA,NOT_USED3 ,NOT_USED4 ,NOT_USED5)
Argument | Format | Description |
NEL | Integer read only scalar | Number of elements per group. In the Engine subroutine, the element data are treated by groups for vectorization purposes. |
NUPARAM | Integer read only scalar | Size of user parameter array. |
NUVAR | Integer read only scalar | Number of user integration point element variables. |
NFUNC | Integer read only scalar | Number of functions used for failure model materials. |
IFUNC | Integer array read only | Array of size NFUNC containing function indexes. |
NPF | Integer array private data | Array used by FINTER (float external
functions). |
TF | Float array private data | Array used by FINTER (float external
functions). |
TIME | Float read only | Current time. |
TIMESTEP | Float read only | Current time step. |
UPARAM | Float array read only | User failure parameter array of size NUPARAM. |
IPT | Integer scalar read only | Current layer or integration points. |
NPT0 | Integer scalar read only | Number of layers or integration points. |
NGL | Integer array read only | Array of size NEL containing the external element number. |
EPSPXX, EPSPYY, EPSPZZ, EPSPXY, EPSPYZ, ESPPZX | Float array read only | Array of size NEL containing strain rates in directions XX, YY, and ZZ and strain rates in directions XY, YZ, and ZX. |
EPSXX, EPSYY, EPSZZ, EPSXY, EPSYZ, EPSZX | Float array read only | Array of size NEL containing strain in directions XX, YY, and ZZ and strain rates in directions XY, YZ, and ZX. |
SIGNXX, SIGNYY, SIGNZZ, SIGNXY, SIGNYZ, SIGNZX | Float array read write | Array of size NEL containing stress in directions XX, YY, ZZ, XY, YZ, and ZX. |
PLA | Float array read only | Array of size NEL containing equivalent plastic strain. |
DPLA | Float array read only | Array of size NEL containing incremental equivalent plastic strain. |
EPSP | Float array read only | Array of size NEL, equivalent of strain rate. |
UVAR | Float array read write | Array of size NEL*NUVAR containing integration point element variables. |
UEL | Float array read write | Array of size NEL, containing the number of layers in which the failure criteria is satisfied for all elements. |
OFF | Float array read write | Array of size NEL containing deleted
element flags.
LENGTH | Float array read only | Array of size NEL, characteristic length of the element |
AREA | Float array read only | Array of size NEL, surface area of integration point |
NOT_USE_I1, NOT_USE_I2, NOT_USE_I3, NOT_USE_I4 | Integer scalar | Not used. Can be used in the future. |
NOT_USED3, NOT_USED4, NOT_USED5 | Float scalar | Not used. Can be used in the future. |
