Starter Subroutine USERWIS
This subroutine reads the input data.
You can specify the number of cards and their format.
Arguments
The argument list of USERWIS and its individual arguments and descriptions are:
C-----------------------------------------------------------------------------------------
SUBROUTINE USERWIS(IIN     ,IOUT    ,NUMNOD   ,ITAB    ,
     .                   X       ,V       ,VR       ,MASS  ,INER    ,
     .                   NUVAR   ,NUVARI  ,UVAR     ,IUVAR   )
Argument Format Description
IIN Integer read only scalar Input file unit (Starter input file) on which the data are read.
IOUT Integer read only scalar Output file unit (Starter output file).
NUMNOD Integer scalar Number of nodes (defined with /NODE option).
ITAB(NUMNOD) Integer array An array of size NUMNOD. This defines the node ID versus Radioss internal node number.
X(3,NUMNOD) Float array Nodal coordinates.
V(3,NUMNOD) Float array Nodal initial coordinates.
VR(3,NUMNOD) Float array Nodal initial rotational velocities.
Mass(NUMNOD) Float array Nodal mass.
INTER(NUMNOD) Float array Nodal spherical inertia.
NUVAR Integer scalar Needed size of global user float array.
NUVARI Integer scalar Needed size of global user integer array.
UVAR(MAXNUVAR) Float array An array of size MAXNUVAR in Radioss Starter. This array is transmitted via the restart file to Radioss Engine, where it has a size of NUVAR.
IUVAR(MAXNUVARI) Integer array An array of size MAXNUVARI in Radioss Starter. This array is transmitted via the restart file to Radioss Engine, where it has a size of NUVARI.
