/DT/SPHCEL
Engine Keyword Generates the SPH cells time step.
/DT/SPHCEL
Δ T sca Δ T min
Data Description SI Unit Example
Δ T sca Scale factor on time step for option SPHCEL.
Δ T min Minimum time step for option SPHCEL.
  1. /DT/NODA is compatible with SPH.
  2. Nodal time step is generally more robust.
