OS-E: 0895 Flat Plate with Thermal Compliance Response
Demonstrates the usage of thermal compliance responses with Topology Optimization in OptiStruct.
Figure 1. Flat Plate with Input Flux in the Entire Surface and Fixed Temperature at the Top Edge
Model Description
- Element Type
- CQUAD4, CHBDYE
- Material Properties
- Young's modulus
- 210000 Nmm2
- Poisson's ratio
- 0.30
- Thermal expansion coefficient
- 1.0E-05 K-1
- Thermal conductivity
- 401.0 W mm-1 K-1
- Free convection heat transfer coefficient
- 25.0 W mm-2 K-1
Optimization Formulation
- Objective
- Minimize thermal compliance (TCOMP)
- Constraint
- Volume fraction (VOLFRAC) ≤ 0.3
Results
Figure 2. Final Optimal Design Results. in a tree-like structure and the plot of element densities
Model Files
The model file used in this example includes:
<install_directory>/hwsolvers/demos/optistruct/examples/plate_therm_comp.fem
