OS-E: 0835 Failsafe Topology Optimization of 3D Column
Demonstrates Failsafe topology optimization of a 3D column, using OptiStruct.
FSO divides the structure into damage zones and generates multiple models (equal to the number of failure zones), wherein each model is the same as the original model minus one failure zone. In this process, the FSO method is applied by running Topology Optimization simultaneously for all such generated models and a final design is output which is optimized to account for all generated models.
Note: If the number of damage zones is large, which means the number of SPMD domains is high. Such a job typically requires to be run on multiple nodes with cluster setup.
Figure 1. FE-Model with Loadcases and Loadstep
Model Description
Conduct a FSO topology optimization of the 2D plate which is undergoing a compression loading (force applied in negative Z-direction). The design space is shown in green in Figure 1. The column is modeled using first order Hexa elements.
Objective
Minimize the compliance
Constrains
Minimize 30% of the volume
Design Variables
Topology Design Variable
Results
Regular Topology optimization runs may not account for the feasibility of a design in situations where a section of the structure fails, and the regular topology optimization design fails even if one column fails. However, with FSO that is not case.
Figure 2. Damage Models
Figure 3. Element Density Results at 35th Iteration
Model Files
The model files used in this example include:
<install_directory>/hwsolvers/demos/optistruct/examples/Topology_Solid_Elems_FSO.fem
