Strain Results Written in Nastran .op2 and .pch Formats
Static Loadcases
1D Elements
CROD Axial Strain
CELAS Strain
CBAR SA1
CBAR SA2
CBAR SA3
CBAR SA4
CBAR Axial
CBAR SA-maximum
CBAR SA-minimum
CBAR SB1
CBAR SB2
CBAR SB3
CBAR SB4
CBAR SB-maximum
CBAR SB-minimum
CBEAM Long Strain at Point C1
CBEAM Long Strain at Point D1
CBEAM Long Strain at Point E1
CBEAM Long Strain at Point F1
CBEAM Maximum Strain1
CBEAM Minimum Strain1
CBEAM Long Strain at Point C2
CBEAM Long Strain at Point D2
CBEAM Long Strain at Point E2
CBEAM Long Strain at Point F2
CBEAM Maximum Strain2
CBEAM Minimum Strain2
CWELD Axial Strain
CWELD Maximum Strain A
CWELD Minimum Strain A
CWELD Maximum Strain B
CWELD Minimum Strain B
CWELD Maximum Shear Strain
2D Elements
Fibre Distance (Z1)
Normal XX Strain (Z1)
Normal YY Strain (Z1)
Shear XY Strain (Z1)
Principal Strain Angle (Z1)
Major Principal Strain (Z1)
Minor Principal Strain (Z1)
von Mises Strain (Z1)
Fibre Distance (Z2)
Normal XX Strain (Z2)
Normal YY Strain (Z2)
Shear XY Strain (Z2)
Principal Strain Angle (Z2)
Major Principal Strain (Z2)
Minor Principal Strain (Z2)
von Mises Strain (Z2)
3D Elements
Normal XX Strain
Shear XY Strain
Major Principal X Cosine
Mid Principal X Cosine
Minor Principal X Cosine
Mean Strain
von Mises Strain
Normal YY Strain
Shear YZ Strain
Mid Principal Strain
Major Principal Y Cosine
Mid Principal Y Cosine
Minor Principal Y Cosine
Normal ZZ Strain
Shear XZ Strain
Minor principal Strain
Transient and Multibody Loadcases
1D elements
CROD Axial Strain
CELAS Strain
CBAR SA1
CBAR SA2
CBAR SA3
CBAR SA4
CBAR Axial
CBAR SA-maximum
CBAR SA-minimum
CBAR SB1
CBAR SB2
CBAR SB3
CBAR SB4
CBAR SB-maximum
CBAR SB-minimum
2D Elements
Fibre Distance (Z1)
Fibre Distance (Z2)
3D Elements
Normal XX Strain
Shear XY Strain
Mean Strain
von Mises Strain
Normal YY Strain
Shear YZ Strain
Normal ZZ Strain
Shear XZ Strain
Eigenvalue Loadcases
1D Elements
None.
2D Elements
Fibre Distance (Z1)
Fibre Distance (Z2)
3D Elements
Normal XX Strain
Shear XY Strain
Mean Strain
von Mises Strain
Normal YY Strain
Shear YZ Strain
Normal ZZ Strain
Shear XZ Strain
Frequency Response Loadcases
1D Elements
CROD Axial Strain
CELAS Strain
CBAR SA1
CBAR SA2
CBAR SA3
CBAR SA4
CBAR Axial
CBAR SA-maximum
CBAR SA-minimum
CBAR SB1
CBAR SB2
CBAR SB3
CBAR SB4
CBAR SB-maximum
CBAR SB-minimum
2D Elements
Fibre Distance (Z1)
Normal XX Strain (real) (Z1)
Normal XX Strain (imag) (Z1)
Normal YY Strain (real) (Z1)
Normal YY Strain (imag) (Z1)
Shear XY Strain (real) (Z1)
Shear XY Strain (imag) (Z1)
Fibre Distance (Z2)
Normal XX Strain (real) (Z2)
Normal XX Strain (imag) (Z2)
Normal YY Strain (real) (Z2)
Normal YY Strain (imag) (Z2)
Shear XY Strain (real) (Z2)
Shear XY Strain (imag) (Z2)
3D Elements
Normal ZZ Strain (real)
Shear YZ Strain (real)
Shear XZ Strain (real)
Normal ZZ Strain (imag)
Shear YZ Strain (imag)
Shear XZ Strain (imag)
  1. The order above reflects the contents of the OP2 file, but post-processors such as HyperView may display results in a different manner.
