Strain Results Written in HyperMesh .res Format
Static, Eigenvalue, Transient and Multibody Loadcases
ALL, DIRECT and TENSOR Options
von Mises Strain
Maximum Principal Strain
von Mises Strain (Z1)
von Mises Strain (Z2)
Von Mises Strain (mid)
P1 (major) Strain (Z1)
P1 (major) Strain (Z2)
P1 (major) Strain (mid)
P1 (major) Strain (max)
P3 (minor) Strain (Z1)
P3 (minor) Strain (Z2)
P3 (minor) Strain (mid)
P3 (minor) Strain (min)
Normal X Strain (Z1)
Normal X Strain (Z2)
Normal X Strain (mid)
Normal Y Strain (Z1)
Normal Y Strain (Z2)
Normal Y Strain (mid)
Shear XY Strain (Z1)
Shear XY Strain (Z2)
Shear XY Strain (mid)
Principal Strain Angle (Z1)
Principal Strain Angle (Z2)
Principal Strain Angle (mid)
Signed von Mises Strain (solid)
P1 (major) Strain (solid)
P2 (mid) Strain (solid)
P3 (minor) Strain (solid)
Normal X Strain (solid)
Normal Y Strain (solid)
Normal Z Strain (solid)
Shear XY Strain (solid)
Shear YZ Strain (solid)
Shear XZ Strain (solid)
VON Option
von Mises Strain
PRINC Option
von Mises Strain
Frequency Response Loadcases
Normal X Strain (Z1) (comp)
Normal X Strain (Z2) (comp)
Normal Y Strain (Z1) (comp)
Normal Y Strain (Z2) (comp)
Shear XY Strain (Z1) (comp)
Shear XY Strain (Z2) (comp)
Normal X Strain (solid) (comp)
Normal Y Strain (solid) (comp)
Normal Z Strain (solid) (comp)
Shear XY Strain (solid) (comp)
Shear YZ Strain (solid) (comp)
Shear XZ Strain (solid) (comp)
  1. "von Mises Strain" and "Maximum Principal Strain" apply to 1D, 2D, and 3D elements simultaneously. Other results apply to 2D or 3D elements exclusively. There are no specific results for 1D elements.
  2. For frequency response loadcases, (comp) may be replaced by (real) (imag) (magn) and/or (phas), depending on the complex format request.
  3. "Maximum Principal Strain" is the maximum absolute principal strain:
    max(abs(P1(Z1)),abs(P1(Z2)),abs(P3(Z1)),abs(P3(Z2))) for shells
    max(abs(P1),abs(P2),abs(P3)) for solids
  4. "P1 (major) Strain (max)" is the maximum major principal strain:
    max(P1(Z1),P1(Z2)).
  5. "P3 (minor) Strain (min)" is the minimum minor principal strain:
    min(P3(Z1),P3(Z2)).
  6. "Signed von Mises Strain" is the von Mises strain with traction/compression sign:
    sign(P1+P2+P3) * VonMises.
