NLOUT
Subcase Information Entry The NLOUT entry can be used to select the incremental result output parameters used for Nonlinear Static Analysis and Nonlinear Transient Analysis.
NLOUT = option
| Argument | Options | Description |
| option | <ID
> No default |
- NLOUT Bulk Data Entries will not be used unless selected in the Subcase Information section.
