OS-V: 0010 Elliptic Membrane
Test No. LE1 The model is a thin plate of thickness 0.1m subjected to a uniform pressure for linear static analysis. OptiStruct examines the direct stress at the point on inside the ellipse on the x-axis.
Benchmark Model
Second order Hexahedral, Penta, Tetra, Quad and Tria elements are used to create the coarse and fine mesh. A uniform outward pressure of 10 MPa is applied on the outer face. The pressure is converted to force and is applied to the nodes for Quad8 and Tria6 elements.
- Young's Modulus
- 210 x 103 MPa
- Poisson's Ratio
- 0.3
Linear Static Analysis Results
| Direct Stress at Point D (MPa) | Normalized with the Target Value | |
| Solid Hexahedral | ||
| Hex8 coarse | 63.15 | 1.467933492 |
| Hex20 coarse | 87.46 | 1.059913103 |
| Hex8 fine | 79.8 | 1.161654135 |
| Hex20 fine | 91.01 | 1.018569388 |
| Solid Wedges: | ||
| Penta6 coarse | 48.68 | 1.904272802 |
| Penta15 coarse | 95.21 | 0.973637223 |
| Penta6 fine | 67.3 | 1.377414562 |
| Penta15 fine | 94.28 | 0.983241409 |
| Solid Tetrahedral: | ||
| Tetra4 coarse | 53.34 | 1.737907762 |
| Tetra10 coarse | 95.96 | 0.966027511 |
| Tetra4 fine | 66.56 | 1.392728365 |
| Tetra10 fine | 95.28 | 0.972921914 |
| Quad Shells: | ||
| Quad4 coarse | 61.83 | 1.499272198 |
| Quad8 coarse | 86.67 | 1.069574247 |
| Quad4 fine | 79.7 | 1.163111669 |
| Quad8 fine | 91.48 | 1.013336248 |
| Triangular Shells: | ||
| Tria3 coarse | 54.06 | 1.714761376 |
| Tria6 coarse | 97.07 | 0.954980942 |
| Tria3 fine | 74.21 | 1.249157795 |
| Tria6 fine | 96.64 | 0.959230132 |
Model Files
The model files used in this problem include:
- /LE1Hex8C.fem
- /LE1Hex20C.fem
- /LE1Hex8F.fem
- /LE1Hex20F.fem
- /LE1Pen6C.fem
- /LE1Pen15C.fem
- /LE1Pen6F.fem
- /LE1Pen15F.fem
- /LE1Tet4C.fem
- /LE1Tet10C.fem
- /LE1Tet4F.fem
- /LE1Tet10F.fem
- /LE1Quad4C.fem
- /LE1Quad8C.fem
- /LE1Quad4F.fem
- /LE1Quad8F.fem
- /LE1Tria3C.fem
- /LE1Tria6C.fem
- /LE1Tria3F.fem
- /LE1Tria6F.fem
Reference
NAFEMS Ltd, The Standard NAFEMS BENCHMARKS TNSB Rev. 3, NAFEMS Ltd, Scottish Enterprise Technology Park, Whitworth Building, East Kilbride, Glasgow, United Kingdom, 1990.
