OS-V: 0360 Simply-Supported Thin Square Plate Harmonic Forced Vibration Response
Test 13R OptiStruct is used to investigate the Peak Displacement in z-direction and extreme fiber bending stress at undamped Natural Frequency (at the center of the plate).
Benchmark Model
The 2nd order and 1st order quad elements are used to model the square plate of thickness 0.05m. The z-rotation and x, y translations are fixed for all the nodes, z-translation is fixed along all four edges, x-rotation is fixed along the edge x=0 and x=10 and y-rotation is fixed along the edge y=0 and y=10. A steady state random forcing with uniform power spectral density (of force) PSD= (100 N/m2)2/Hz is induced in the z-direction. For modal analysis solution, a damping ratio of 0.02 is applied in all 16 modes and for direct solution, Rayleigh damping factor α1=0.299 and α2=1.339×10-3 are given.
The material properties are:
Young’s Modulus
200 × 109 N/m2
Poisson’s Ratio
0.3
Density
8000 kg/m3
Frequency Response Summary
The frequency of each targeted mode is normalized with the closed form solution.
f*
Closed form solution
  Peak Displacement PSD (mm2/Hz) Peak Stress PSD ((N/mm2)2/Hz) Frequency (Hz)
Reference Solution 2063.20 1025.44 2.377
HOE
Direct Solutions 2232.98 1411.14 2.322
Normalized 0.923967075 0.726674887 1.023686477
Modal Solution 2241.33 1416.89 2.324
Normalized 0.920524867 0.723725907 1.022805508
LOE
Direct Solutions 2045.23 951.00 2.349
Normalized 1.008786298 1.078275499 1.011919966
Modal Solution 2065.73 960.22 2.345
Normalized 0.998775251 1.067921935 1.013646055
Model Files
The model files used in this problem include:
<install_directory>/hwsolvers/demos/optistruct/verification
  • /Test13RHOED.fem
  • /Test13RHOEM.fem
  • /Test13RLOED.fem
  • /Test13RLOEM.fem
Reference
NAFEMS Ltd, The Standard NAFEMS BENCHMARKS TNSB Rev. 3, NAFEMS Ltd, Scottish Enterprise Technology Park, Whitworth Building, East Kilbride, Glasgow, United Kingdom, 1990.
