OS-T: 1110 Modal Analysis Setup
In this tutorial, you continue to gain an understanding of the basic concepts for creating a OptiStruct input file. More specifically, learn how to set up a model for modal analysis, specify solver specific controls and also submit an input file to the solver from HyperMesh.
The channel_brkt_modal.hm file is used for this tutorial. It contains the bracket and channel assembly pictured below.
Launch HyperMesh and Set the OptiStruct User Profile
Open the Model
Set Up the Model
Review and Edit the Materials
Create Load Collectors
Apply Constraints (OptiStruct SPC) on the Channel
Map the Constraints
Define the Load Step
- In the Model Browser, right-click and select .
- For Name, enter normal_modes.
- For Analysis type, select Normal modes.
- For METHOD(STRUCT), select modal.
- For SPC, select the load collector constraints.
