Analysis of Aircraft Fittings
Fittings for aircraft panels are described.
Figure 1. DFEM Model
The above fitting is analyzed for tensile and compressive loads, in two different load steps.
Figure 2. Details of Loads and Boundary Conditions
The analysis is performed with different analysis types.
Linear Static Analysis
Figure 3. DFEM Model Results from Linear Static Analysis
Nonlinear Analysis with Pre-loaded Fasteners
Figure 4. DFEM Model Results from Nonlinear Static Analysis. (a) before applying an external load; (b) after the application of external load
Large Displacement Nonlinear Analysis with Pre-loaded Fasteners
Figure 5. DFEM Model Results from Nonlinear Large Displacement Static Analysis
Model Files
- /Linear_static_fittings.fem
- /LGDISP_preloaded.fem
