Multiphysics Solution
Thermal Analysis
A fingerprint scanner is initially kept in cold conditions and then moved to hot conditions, the temperature variation, as well as the structural performance of scanner, is analyzed when it is moved from cold to hot, as well a hot to cold weather conditions.
Use-Case
Human fingerprints are practically unique, thus the application of a fingerprint scanner is enormous. As the weather changes from summer to fall to winter, fingerprint sensors on the devices may start to have troubles. The fact that heat makes things expand and cold makes them contract, it is necessary to evaluate the structural performance after the temperature variations.
FEA Model Description
![](../../images/solvers/hitech_electronics_multiphysics_thermal_analysis_model.png)
Figure 1. Fingerprint Scanner
Results
![](../../images/solvers/hitech_electronics_multiphysics_thermal_analysis_results.png)
Figure 2. Temperature Distribution in Cold and Hot Conditions
Model File
<install_directory>/hwsolvers/demos/optistruct/examples/Fingerprint_scanner.slb
Thermal Fluid-Structure Interaction Analysis
Thermal fluid interaction is accurately analyzed using OptiStruct.
Use-Case
A light bulb is a device that produces light from electricity. In addition to lighting a dark space, they can be used to indicate than an electronic device is on, to direct traffic, for heat, and many other purposes. If you want to change or replace a light bulb which has on for a long time, it will very hot to touch.
![](../../images/solvers/hitech_electronics_multiphysics_thermal_fluid_structure_model.png)
Figure 3. Thermal Fluid-Structure Interaction Analysis
In this model, the air, which is fluid in this analysis, is meshed using SimLab and the filament gives heat generation, due to electricity of 1.2 W/mm3. The fluid mesh is an important step as it will transfer the heat from the filament to the glass. Appropriate material properties are given to the filament (tungsten), air-fluid (Argon gas), and glass. In this solution, CFD thermal flow is solved using AcuSolve and Structural Stress Analysis is solved using OptiStruct.
Results
![](../../images/solvers/hitech_electronics_multiphysics_thermal_fluid_structure_results.png)
Figure 4. Temperature Variation
Model File
<install_directory>/hwsolvers/demos/optistruct/examples/light_bulb.slb
