ValueAtTime
Computes the value of a signal at a particular time, T=t*.
Assume that you wish to compute the steering wheel angle in a suspension at T=2.4 seconds.
Here is a code snippet that will compute the steering wheel angle at T=2.4s.
>>> val = ValueAtTime (label   = "Steer Wheel Angle @ T=2.4s",
                       measuredValue =  "RTOD * AZ(77,66)",
                       atTime        = 2.40,
                       delta         = 0.1,
The calculation in ValueAtTime is implemented for this example as:(1)
f(t)  = measuredValue δ (t)  = Step (time, atTime-delta, 0, atTime, 1) +          Step (time, atTime, 1, atTime+Delta, 0) - 1 response =  ∫ t o t f f(t)  δ (t) dt ∫ t o t f δ (t) dt = 1 delta ∫ t o t f f(t)  δ (t) dt MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2Caerbd9MBZ9 gBHnharuavP1wzZbItLDhis9wBH5garmqr1ngBPrgitLxBI9gBaerb d9wDYLwzYbItLDharqqr1ngBPrgifHhDYfgasaacH8qrps0lbbf9q8 WrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbba9q8WqFfea0=yr0RYxir=J bba9q8aq0=yq=He9q8qqQ8frFve9Fve9Ff0dmeaacaGacmWadaWaai GacaabbiqafiaakqaabeqaaabbaaaaaG+acXwDLbWdbiaabAgacaqG OaGaaeiDaiaabMcacaqGGaGaaeiiaiaab2dacaqGGaGaaeyBaiaabw gacaqGHbGaae4CaiaabwhacaqGYbGaaeyzaiaabsgacaqGwbGaaeyy aiaabYgacaqG1bGaaeyzaaqaaiabes7aKjaabIcacaqG0bGaaeykai aabccacaqGGaGaaeypaiaabccacaqGtbGaaeiDaiaabwgacaqGWbGa aeiiaiaabIcacaqG0bGaaeyAaiaab2gacaqGLbGaaeilaiaabccaca qGHbGaaeiDaiaabsfacaqGPbGaaeyBaiaabwgacaqGTaGaaeizaiaa bwgacaqGSbGaaeiDaiaabggacaqGSaGaaeiiaiaabcdacaqGSaGaae iiaiaabggacaqG0bGaaeivaiaabMgacaqGTbGaaeyzaiaabYcacaqG GaGaaeymaiaabMcacaqGGaGaae4kaiaabccaaeaacaqGGaGaaeiiai aabccacaqGGaGaaeiiaiaabccacaqGGaGaaeiiaiaabofacaqG0bGa aeyzaiaabchacaqGGaGaaeikaiaabshacaqGPbGaaeyBaiaabwgaca qGSaGaaeiiaiaabggacaqG0bGaaeivaiaabMgacaqGTbGaaeyzaiaa bYcacaqGGaGaaeymaiaabYcacaqGGaGaaeyyaiaabshacaqGubGaae yAaiaab2gacaqGLbGaae4kaiaabseacaqGLbGaaeiBaiaabshacaqG HbGaaeilaiaabccacaqGWaGaaeykaiaabccacaqGTaGaaeiiaiaabg daa8aabaWdbiaabkhacaqGLbGaae4CaiaabchacaqGVbGaaeOBaiaa bohacaqGLbGaaeiiaiaab2dacaqGGaWaaSaaaeaadaWdXbqaaiaabA gacaqGOaGaaeiDaiaabMcacaqGGaGaeqiTdqMaaeikaiaabshacaqG PaGaaeiiaiaabsgacaqG0baaleaacaWG0bGaam4Baaqaaiaadshaca WGMbaaniabgUIiYdaakeaadaWdXbqaaiabes7aKjaabIcacaqG0bGa aeykaiaabccacaqGKbGaaeiDaaWcbaGaamiDaiaad+gaaeaacaWG0b GaamOzaaqdcqGHRiI8aaaakiabg2da9maalaaabaGaaGymaaqaaiaa bsgacaqGLbGaaeiBaiaabshacaqGHbaaamaapehabaGaaeOzaiaabI cacaqG0bGaaeykaiaabccacqaH0oazcaqGOaGaaeiDaiaabMcacaqG GaGaaeizaiaabshaaSqaaiaadshacaWGVbaabaGaamiDaiaadAgaa0 Gaey4kIipaaaaa@E08D@
