RD-T: 3510 Cantilever Beam with Bolt Pretensioner
This tutorial demonstrates how to simulate a simple cantilever problem with a concentrated load at the free end, using Dynamic Relaxation (/DYREL) method to obtain a static solution.
図 1.
The model description is as follows:
- UNITS
- Length (mm)
- Simulation time
- cantilever_start_0000.rad [0 - 40 ms]
- Steps to setup this model
- Fix the Cantilever Beam to the support with a 10 kN pre-tension. The bolt attains 10 kN in 10 ms and remains constant thereafter.
- Material Used
- Elasto-plastic material /MAT/LAW2.
- [Rho_I] Initial density
- 7.83e-6 Kg/mm3
- [E] Young's modulus
- 205 GPa
- [nu] Poisson's ratio
- 0.29
- [Iflag]
- 1
- [a] Yield Stress
- 0.792 GPa
- [UTS] Ultimate tensile stress
- 0.9771 GPa
- [E_UTS] Engineering strain at UTS
- 0.0638
- Input file
