OS-V: 0100 Membrane with Hot-Spot
Test No. T1 OptiStruct examines the direct stress in y direction at a point D outside the hot-spot for linear thermos elastic analysis.
図 1.
Benchmark Model
Quarter model is considered and Quad4 elements with the specific mesh specifications are used for model building. The hotspot area is maintained at a temperature 100°C.
The material properties are:
Hot-spot Area
Young's Modulus
100 x 103 MPa
Poisson's Ratio
0.3
Coefficient of thermal expansion
1 x 10-5/°C
Remaining Area
Young's modulus
100 x 103 MPa
Poisson's ratio
0.3
0.0
Linear Static Analysis Results
All results are normalized with the target value (50 MPa).
Quadrilateral Shells Direct Stress in y Direction at a Point D, Outside Hot-spot (MPa) Normalized with the Target Value
Quad4 45.51 1.098659635
Model Files
The model files used in this problem include:
<install_directory>/hwsolvers/demos/optistruct/verification/T1Quad4.fem
Reference
NAFEMS Ltd, The Standard NAFEMS BENCHMARKS TNSB Rev. 3, NAFEMS Ltd, Scottish Enterprise Technology Park, Whitworth Building, East Kilbride, Glasgow, United Kingdom, 1990.
