OS-V: 0300 Deep Simply-Supported Beam Harmonic Forced Vibration Response
Test 5H OptiStruct is used to investigate the Peak Displacement in y-direction and extreme fiber bending stress at undamped Natural Frequency (at the mid-span node).
![](../../../images/solvers/nafems_deep_simply_supported_beam_harmonic.png)
図 1.
Benchmark Model
Timoshenko beam and Engineer’s beam elements are used to model the simply-supported beam which consists of 10 elements. The displacements in x, y, and z direction, as well as the rotation in x direction are fixed at the end A. In addition, the displacements in y and z direction are constrained at end B. A steady state harmonic forced vibration F=F0 sin ωt is induced in the y-direction. (F0=106 N/m uniformly distributed, ω=2πf, f=0 to 4.16 Hz). For modal analysis solution, a damping ratio of 0.02 is applied in all 16 modes and for direct solution, Rayleigh damping factor α1=5.36 and α2=7.46×10-5 are given.
- Young’s Modulus
- 200 × 109 N/m2
- Poisson’s Ratio
- 0.3
- Density
- 8000 kg/m3
Frequency Response Summary
f*
- Closed form solution
Peak Displacement (mm) | Peak Stress (N/mm2) | Frequency (Hz) | |
Reference Solution | 13.45 | 241.9 | 42.65 |
PBEAML | |||
Direct Solution | 13.42 | 236.1 | 43.02 |
Normalized | 1.002235469 | 1.024565862 | 0.991399349 |
Modal Solution | 13.56 | 238.61 | 43.16 |
Normalized | 0.991887906 | 1.01378819 | 0.988183503 |
PBEAM | |||
Direct Solution | 12.27 | 238.21 | 45.28 |
Normalized | 1.096169519 | 1.015490534 | 0.941916961 |
Modal Solution | 12.3 | 238.89 | 45.34 |
Normalized | 1.093495935 | 1.012599941 | 0.94067049 |
Model Files
The model files used in this problem include:
- Test5HPBEAMLD.fem
- Test5HPBEAMLM.fem
- Test5HPBEAMD.fem
- Test5HPBEAMM.fem
Reference
NAFEMS Ltd, The Standard NAFEMS BENCHMARKS TNSB Rev. 3, NAFEMS Ltd, Scottish Enterprise Technology Park, Whitworth Building, East Kilbride, Glasgow, United Kingdom, 1990.
